RCU Forums - View Single Post - Going Diesel
Thread: Going Diesel
Old 05-30-2005 | 07:48 PM
AMB
Default RE: Going Diesel
Not bad also understand you have a new piston and liner, when it is well seated maybe an other hour of running the compression will pick up and you will backing out the compression screw you will pick up close to an other 500rpm also your needle will only have to change about 1/2 turn in or out at this point for a good tuned engine you now can confine your fiddling to a fiddle martin
