RE: GP U-Can-Do EP Does!!!
if you go to ebay there are a lot of cheap outrunners. they would produce enough thrust to hover at about 3/4 throttle, depending on how you built it. while this isn't much power for punch out if you run into trouble, it is by far the cheapest option
good luck
-richo
