RCU Forums - View Single Post - Tranceiver with antenna collapsed
Old 05-30-2005 | 10:17 PM
joesabido's Avatar
joesabido
Default RE: Tranceiver with antenna collapsed
As Raideron said, if you remove the Tx crystal you can use it with the antenna collapsed (for flight simulation ONLY! )
When you remove the crystal the signal never reaches the final stage amp since you are removing the "bridge" that modulates the signal into the desired frequency
Cheers
