RCU Forums - View Single Post - ARF & RTF
Thread: ARF & RTF
Old 05-31-2005 | 10:32 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: ARF & RTF
If you are using the CA type hinges this could be a problem. With CA hinges one should push the surface up tight. Then deflect it . Then apply the CA. A gap in the hinge line can induce some flutter. I prefer to use the method above and if there is a gap seal it with some clear Monocoat or tape.
David
