RCU Forums - View Single Post - P60 starter O ring worn out?
Old 05-31-2005 | 10:49 AM
Gordon Mc
Default RE: P60 starter O ring worn out?
Is the starter motor assembly properly aligned ?
With the flexible mount approach used by Jetcat, I've found that you may sometimes be unaware that due to interference with the airframe, or simply being bumped during installation, the starter mount may be slightly misaligned (and even pulled very slightly out), causing similar odd noises etc. during the start attempt.
