RE: OMP Edge....Almost there!
Westy, sounds good on the throws and expo. I also use more expo when I go to high rates. Skip the landing mode setup though, you don't need it and it's only going to mess you up if you accidently hit that switch.
Shovel-head, You definately need to balance with everything installed plus don't judge the balance until you fly it. The big wide profile wing allows for a cg much further bach than you are probably used to. Still to the recommendation per the instructions and you will be fine.
