RE: newbie with new toys
As long as you use a teflon liner the brass should be fine. A word of caution, When you bend your brass tube bend it by hand and make small bends. Also put the flex cable in the tube before you bend it. This will give you a better bend and most of all keep you from kinking the tube. I kinked a few tubes before I figured this out.
