RCU Forums - View Single Post - OMP Edge....Almost there!
Old 05-31-2005 | 02:28 PM
westy1957's Avatar
westy1957
Default RE: OMP Edge....Almost there!
Very good!!! The test fly survived!! But not without little problems:
1) to have exact the CG at 1.85" aft main spar I had to advance the battery near the engine and put a little plomb on the nose. In that way it flies horizontal also inverted.
2) I had some trouble (some engine cut offs) with carburation the OS 46 AX. Solved with fuel 20% oil and only 5% nitro.
3) With the APC 12.25X3.75 I am afraid to go at max power because I hear the engine going too high with a prop so thin.....
4) When I feel the engine perfect: then I could fly well: It flies very beautiful!! But I need to learn a lot before doing some manouvers near the ground like hovering ecc ecc......
Anyway thankyou very much!!! At the field everyone is interested at my new Edge!!!!!
ID:	278699   Click image for larger version
ID:	278700   Click image for larger version
ID:	278701   Click image for larger version
