RCU Forums - View Single Post - modeltech twister
Old 05-31-2005 | 05:02 PM
kinverflyer
Default RE: modeltech twist
What I do with belly pans is mark the position with a pencil then with a fine tipped soldering iron (highest setting) burn through the film to the wood on the inside of the pencil lines. Then using thick cyano glue the belly pan in place. This method makes sure you dont damage the wood and that you glue straight to the wood and the film edges are sealed.
