RCU Forums - View Single Post - Starter/Battery problem?
Old 05-31-2005 | 09:17 PM
red head
Default RE: Starter/Battery problem?
Take the switch apart carefullyly and you will see the foam (refered to before )under a lond rectangular flat piece of metal. When you squeese the handle the metal makes the contact then when you let go the foam pushes it back and the contact is broken. It's really simple and just some foam will fix it, it's just old. I used a small piece of foam from a piece of pipe insulation to fix mine. ENJOY!!! RED
