RCU Forums - View Single Post - radio interference
Old 10-06-2002 | 10:08 PM
Diablo-RCU
Default radio interference
Try swapping plugs first to see if that makes a difference, it's cheap too. The CM6 plugs are not resistor. There's a resistor in each plug cap, perhaps one has gone bad. You can get a set of new boots from Desert Aircraft...$40. See if you can borrow an ignition from a buddy to swap and test.
