RE: Question on 10X Heli Mixing
Actually, the workaround I had come up with was to mix aux3 to aux2, and vary either the endpoints of 2 or the mix percentages, and that way, (since I use code 44 controlled by the rudder d/r switch) it drops out in the same place anyhoo. Found this by accident by noting that it was mixing the switch input and not the channel output.
Thanks anyhow - this is what I suspectesd, but just wanted to be sure by asking the "guru"
- Tim
