Originally posted by kram
Late last fall I posted a question about bothersome radio interference on a big 330 gasser and got a lot of help off this forum.
My winter radio make-over included the following:
1) Switched my FM receivers out to PCM
2) Took my twin receivers' antennae out of parallel
3) One twist/inch to the longer servo leads
4) Fine-tuned the linkages on my ganged servos
5) Adopted the PCM range-check protocol from winter/2002 Horizon Hobby catalog
Now that I've got the first couple of range checks and flights done, I can report complete success. My range checks are normal beyond 250', engine on and off, and I've had no detectable hits after some "stress" flying.
Thank you for all the advice. I feel like you saved my plane from the junk-heap or, worse yet, permanent hangardom.
mt
Here is my solution for twin antena
twin antena
