its not 7 screws, you have to unscrew the bottom (8), then a screw on the side (1), then another 2, then put it back together.... 2 for the shocks, and another 2 for the shafts for the wheels, and 2 bolts to take off the tires... thats 17.. unless there is another way to do it, plz tell me, i dont want to do that again....
also, this is my tire selection, i had to shave off a little plastic to make the rims fit...
i have rpm crome blue rims in front and rear, http://www2.towerhobbies.com/cgi-bin...&I=LXDNC4&P=ML
then i have gladiators in the rear, http://www2.towerhobbies.com/cgi-bin...?&I=LXDX67&P=7
and proline edges in the front, http://www2.towerhobbies.com/cgi-bin...?&I=LXFDX3&P=7
combonation works great, but if you want to do flips, use paddles (no duh), or dirt hawgs,
http://www2.towerhobbies.com/cgi-bin...&I=LXDU11&P=ML
my gladiators work fine for flips, its just that you need a little bit more air for them, and i borrowed my friends hawgs, but they came off in the middle of a flip because of the rpms.[:@].
make sure you use VERY VERY VERY strong glue, and a lot of it, the thiner the better.
