Here is a question I was PM'd,
So do you hook the canards with a Y harness with elevator?
Or put them on a seperate chanell with a mix?
Also i have not used canards before is this right when up elevator is
applied the Trailing edge of the canard goes down is this correct?
Hope the anonymous doesn't mind me sharing, but here you go:
The best way to run them together (and you do run them together) is seperate channels and a computer mix percentage wise, for specifics on that, send me your phone number if you use JR, if you don't call someone else cause I can't help you
The canard works opposite your elevons. The trailing edge goes down and when it does, it works kind of like a big flap, air hits it and the pushes the nose of the airplane UP.
