RCU Forums - View Single Post - 3D Buddy as a first E-plane???
Old 06-02-2005 | 02:15 PM
Mike Parsons's Avatar
Mike Parsons
Default RE: 3D Buddy as a first E-plane???
Vic Vic,
If you have flown the Dazzler and are comfortable with four channel planes, then I think you will enjoy the 3D Buddy. The only difference is the power plant. As far as flying goes, it is a well mannered plane. Just follow the recommended control throws and CG recommendations and I see no problem with you starting off with this plane.
I flew one a month or so ago and it did very well. Well tamed with low rates and wild on high. I do have on precaution and that is dealing with Lithiums. They are to be respected and I ask that you read up on them in the battery forum if you have never used them before. There are special precations one must take with Lithiums.
-Mike
