RCU Forums - View Single Post - Look what hapens when.....
Old 06-02-2005 | 04:23 PM
tp777fo's Avatar
tp777fo
My Feedback: (28)
Default Look what hapens when.....
you crash all your airplanes. After losing both an F-16 and a SM Hawk with in a year I am bingo airplanes. Finally got off my duff and finished my trailer using the great ideas of Gus Hudson (Thanks Gus!) A dual use trailer, the carpet is normal outdoor pool carpet from Home Depot. The bike chock is from Wheeldock. It lifts in or out in less than 5 seconds using a pin and cotter key. Cock it, drive onto it and push the lever.... it graps and firmly holds the front wheel. Flush mounted D-rings to help hold down my 97 Heritage Softail Classic. The main shelf is installed with E-track that allows it to lift in/out with little effort. The only things remaining is a steel mesh mounted to the shelf to hold the bungee cords and a ramp. Next project - something to put in the trailer... a new PA F-16 in Thunderbird colors and scale gear. Hope the Euro fall like a rock over the next few days!
ID:	279578   Click image for larger version
ID:	279579   Click image for larger version
ID:	279580   Click image for larger version
