RCU Forums - View Single Post - Engin stops
Thread: Engin stops
Old 06-02-2005 | 05:48 PM
tail strike's Avatar
tail strike
Default RE: Engin stops
Thanks Geistware,
what do you think of puting a piece of bras tubing between the stoper and the clunk to keep the clunk from going to the front of the tank?
I think I saw that sugestion somewhere.
ORIGINAL: Geistware
I would look for a pinched or damaged fuel line inside the tank. I have had this happen twice and it will run fine until the fuel gets below the stopper then it stops. If you see that this is the case, put a short piece of fuel line over the clunk line at the clunk and the stopper tubing. This will make it stiffer and prevent air leaks if it is damaged by the tubing.
