Also, some tail draggers are a little Squirrelly on take-off runs if the gear is too far back. Depending on other design factors, straight tracking can be difficult and may produce unpredictable ground loops.
One rule of thumb is to align the axles directly below the leading edge of the wing. This assumes a straight wing design with no sweep back. Just make the measurement at 90 degrees to the chord line of the wing.
