Hey CeeGee,
I've read some good things about the world models CAP, about the only bad thing was nobody likes the pilot.It does have the CAP tuck with rudder, so just mix in some ele.. CAPs elevators are sensitive, they have a tendency to snap with too much. So just dial it in pull back and around you go. The prison is behind our field so its no factor.
Welcome Dave,
I'd go with CeeGees recommendation about the longer arms, and use some good servos, I've stripped some with this plane. I use hitec 635s now, and they work great.
Hope it helps.........SPUDs out
