RCU Forums - View Single Post - Basic Electrics Questions SAVE ME!!!
Old 06-03-2005 | 05:27 AM
Glacier Girl's Avatar
Glacier Girl
Default RE: Basic Electrics Questions SAVE ME!!!
Ok, It MAY work. Depends on the plane and prop you plan on running.
As an example, I run a PZ Cub with a 370/4100 BL motor, with a 6x1 gearbox, spinning an 8 X 8.5 prop. This set up pulls 8 amps continuously. Your pack is good for 19 amps continuous.
Your Esc is Good for 25. If you give me the rest of the info, prop?,gear box or direct drive?, ratio of gearbox if used?, type of airplane with weight,wingspan, and area? I can run Motocalc and some of the other calc programs and tell you if it will fly.
