RE: U-Can-Do 3d 46?
Hopefully the weather will hold out for some flying tomorrow morning. I am going to take some of the weight off the front to move my CG back a little bit. See if I cant start proving how easy this plane makes maneuvers.
I also want to set up a couple of other changes this evening. The first is to give myself a little more Rudder Throw. I berly use it unless i am trying a trick, so i might as well have a lot of throw. I dont have Duals on my rudder so I have to live with what i set it to for everything.
I have a Futaba 6exa. I have Dual Rates on my Elevator and Ailerons, can do some mixing, end point adjustement and exponential. I learned to fly with the basic Analog so I am still getting used to things like expo.
You guys got any suggestions on what kind of expo and mixing i should set up.
