I had finally gotten my confidence level in the R149DP up enough to test fly my 33% H9 Edge this weekend and then I read this thread this morning.
http://www.rcuniverse.com/forum/m_3037768/tm.htm
What filters did they replace and why? Do all the receivers need to have this modification done or did the receiver I got from Tower a month ago already have it done?
I've done a range check with and wthout the DA100 running and I get 130 ft. with the antenna fully collapsed ( 9CAP ) and I put the receiver in a small glow plane and flew it with no incidents.
I'm running 4 JR 2731 servos ( w/matchboxes ) on the ailerons, 2 JR 8611's on the elevator halves and 1 8611 on the rudder. Power is 2 X 1800 mah ni-cads on two switches.
One other quick question: I have the elevator halves on Ch. 2 and 7. There is a noticable lag in the Ch. 7 half. Is this normal or is there something in my setup causing this?
