How to change incidence?
if stab is already glued, then wing is your only answer, depending on which plane type you are talking about the fix could be easy or not, also if is a trainer or wwi plane 1/2 degree is not that bad however pattern or serious arobatic type plane need to be right on the money.-
What plane are you trying to correct??
