RCU Forums - View Single Post - Elec. conversion CG
Old 06-04-2005 | 10:51 AM
tf2psycho
Banned
Default RE: Elec. conversion CG
i use velcrow and wire
i put small hole right behind propshaft in the fuse then i hag and slide the batt up or down the fuse until it hangs at the CG i want ...keep in mind this if what i do for the foamie so not sure how easy it will be for balsa to make hole and hang entire plane
might be to heavy and wire rip through the balsa huh
