RCU Forums - View Single Post - finding thrust needed for parkflyer
Old 06-04-2005 | 04:07 PM
andyg
Default finding thrust needed for parkflyer
The plane specs: span = 40in. length = 28in.
weight = 30 oz. wingloading = 15 oz/sq ft. chord = 7in. aspect ratio = 5.5
airfoil = Clark Y
This is a high wing trainer so it doesn't need to be fast just be able to climb nicely.
I plan to use a Lipo. The actual plane doesn't weigh 30 oz. it is just an estimate for when all of the UAV equipment is in it.
The equipment for the initial rc flying is around 4 oz. including a motor estimated at .88 oz. I am making it out of blucor foam so it should not be to heavy. I'm guessing it would really turn out to be around 15-20oz. with radio gear. Which would bring the wing loading to around 7-10oz./sq ft. I just want to have a little extra power in case I want to put a few ounces of electronics on it.
Do you think I need more wing area? Do you think 15 oz. /sq ft. is a lot. What do your foam parkflyers usually come out to? Thanks for your help
P.S. I have a 1300 mah 2s Lipo and a 1100 mah 3s lipo but if these end up I think they are rated at 8c and 10c respectively. But if these won't work I'm willing to buy a new one for my new plane.
Does anyone have a suggestion about the amount of thrust I'll need to get this plane flying? Any help would be greatly appreciated. THANKS
Andy Goessling
[email protected]
andyg
View Public Profile
Send a private message to andyg
Find More Posts by andyg
Add andyg to Your Buddy List
Browse andyg' gallery
