RE: Fox .25 BB problem
Pull the fuel line. They stop every time when you do that.
If it's a real issue to you, remove the carb, clean the mounting area carefully to remove oil residue, and then
put a FINE BEAD of RTV on the seat. Let it skin over for a few minutes then reassemble. You should be fine.
This is a really nice little motor...don't booger it up.
'Race
