Trev, I did think about your bracket but the problem I'm having is the the connecting bit has to run perpendicular to the spar not parallel to it as on your bracket. I'm afraid the solution is going to be some bit that requires soldering.
I wish Donnie would get on with his wing so I can see how he'll do it since I'm using the same wood laminated aluminum method as he is on the cabane struts. I'm really tempted to just permanently install a bolt (downward) through the spar to that it would attach to the cabane with a simpel (lock?) nut.
Bob, how about you? How are you holding the wings on your SE5a on?
