RCU Forums - View Single Post - How to attach upper wing without weakening spar?
Old 06-05-2005 | 01:17 PM
abufletcher's Avatar
abufletcher
Default RE: How to attach upper wing without weakening spar?
Trev, I got all excited when I read the aluminum rib idea. But then I remembered that there isn't a rib at the point where the cabanes connect. Oh well... maybe I can use that idea on the interplane strut connection.
Bob, the spar (which is of the box spar type) is only about 10mm wide and I'd have to drill a hole at least 4mm. Maybe I could wrap it with glass first...
