RCU Forums - View Single Post - Formosa not taking off
Old 06-05-2005 | 05:28 PM
TGDF's Avatar
TGDF
Default RE: Formosa not taking off
ORIGINAL: barelias
I got a formosa with E-go brushless which is 3700 rpm , 25amp phonex,Gws gear(B) and i made a 9cell nimh pack. Its not taking off from ground even after 50 ft or more. the prop recommended
Sorry guys, for my money, and I'm not familiar with this setup at all, any light aircraft that will accelerate for 50 ft and not take off with the recommended propeller, the first thing I'd check is the center of gravity. Those are all the symptoms of a CG that's way too far forward. Beyond the LE even.
Esp when the writer alludes to having cracked up from a hand launch. If you hand launch and can't keep the nose up......check the CG.
