RCU Forums - View Single Post - Eflight Ultimate ???
Old 06-05-2005 | 09:15 PM
SigMan's Avatar
SigMan
My Feedback: (21)
Default RE: Eflight Ultimate ???
Would this be a good set-up???............................................. .......................................Brushless Himax 2812-0850 & Castle Phoenix 25 ESC COMBO
Suggested Retail Price: 69.95
40159 - 400091 - (C)
Himax HC 2812-0850 Brushless Outrunner Motor
Himax HC2812 series brushless motors are designed for RC model airplanes with all up weight between 9 to 20 oz. It comes with both a stick mount radial mount, prop saver as well as all the screws and connectors. The motor shaft is reversible in both the front and back of the motor.
Specifications:
* Weight: 2.12 oz (60 g) including the weight of the stick mount
* Max Power: 160 W Normal
* Max RPM: 20,000
* Diameter: 1.09" (27.9 mm)
* Length: 1.14" (28.9 mm)
* Shaft Diameter: 4mm (0.157")
* Max Case Temp: 149 F (65 C)
* Mounting Screw Thread: 2.5 mm, Max Depth 4.5 mm on 0.625" ( 16.0 mm) bolt circle
Electric Specifications:
Kv: 850 RPM/v, Rm: 0.169 Ohm, Io: 0.6 A, Efficient Operating Current: 4 to 11 A, Max Current: 14 A for 15 seconds
Phoenix 25 -- Smaller, Lighter and Less Expensive!
The Phoenix-25 ESC can be used in aircraft and helicopter installations and is ideal for Astro 020, Astro 05, Aveox 2713, Mega 1615, Jeti Phasor (under 25 amps) and Hacker B-20 and B-40 motor applications.
With it's feature-rich user settings, the Phoenix-25 can be set up for almost any installation using 25 amps or less. Three timing settings, over-current protection, helicopter govenor mode, five cut-off voltages and more! It even fits comfortably in narrow sport fuselages.
Castle Creations Phoenix 25 Specifications:
Cells w/BEC: 5-10
Cells w/o BEC: 5-16
Continuous: 25 amps
Surge: 40 amps
Switching Rate: 11,000 Hz
Resistance: 0.0065 Ohms
Brake: Yes
Low Voltage Cut-off: Programmable
Reversible: Yes - change any two wires
Size: 1.08 x 0.91 x 0.16 in.
Weight (with wires): 0.6 oz. (17g)
-Universal Connector
