RCU Forums - View Single Post - sig lt-40 wing joining
Old 06-06-2005 | 01:20 AM
robflyer82
Default sig lt-40 wing joining
Hi, I'm building my first kit, an LT-40, and will be coming up on joining the wings soon. I've read that some people use epoxy instead of thin CA for added strength. Has anyone done here done this? If so, how? Is epoxy thin enough to use the same procedure that is in the manual or would i have to do things differently? I figure if its too thick, I would have to epoxy the MADBs to the main spars on one wing, let it sit, then epoxy the MADBs and the gap on the other side all at once instead of two separate steps like in the manual. Does this make sense?
Rob
