RE: Can all program data from 9C be transferred to 9C Super?
Yep its a one way conversion. You copy the models to the campaq from the 9C
On the Super
Hold down MODE and END buttons while turning on the TX.
Select "T9C-Pac>Update" by using the cursor up/down button.
Press and hold the wheel for 1 second to start data conversion.
You can't use the converted compaq in a standard 9c again. I just stuck the campaq that came with the super in the 9c and formatted it. If you have more than 6 models to convert you can copy them to the transmitter memory and put the campaq back in the 9c, format it and do the process over again.
