RE: Confused as to which engine mount to get.
Before you settle on the engine mount, have you considered the distance from the firewall the engine will be mounted? That mount is a little on the short side and you may find that the engine when mounted is not forward enough. Just something to consider if you if you haven't done so already.
DaveB
