RCU Forums - View Single Post - painting ABS plastic....
Old 06-06-2005 | 11:43 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: painting ABS plastic....
2slow,
I'd put down a primer coat too. Not only does it give your paint a constant color underneath, it will help the paint bond better. Once you lay down the primer coat, wet sand it with 400 grit paper to give you a smooth surface. If you have to, lay down 3-4 coats of primer. This is one thing primer is designed for, to help smooth the surface and fill in any small defects, and to give your paint a better surface to bond to.
If you want a good finish coat, after the primer lay down 3-4 coats of your "color" and wet sand with 400 grit paper between each coat. This will give you a final coat that looks like it has "depth" to it.
Hope this helps.
Ken
