RCU Forums - View Single Post - First build - Sig SE started
Old 06-06-2005 | 12:06 PM
  #136
DamonTX
Default RE: First build - Sig SE started
Tychoc...Thanks, this looks like it http://www2.towerhobbies.com/cgi-bin...?&I=LXNM65&P=0 I'm going to order a few sets, anything's gotta be better than what's supplied with the kit. (Probably my only complaint with the kit..LOL)
The best way to describe the twin was incredibly smooth. It was a little faster than my others that have a single .46FX, the twin has 2 .25FXs. I put everthing I knew into setting it up before flight. There was an issue with balance since both tanks are behind the CG (my design flaw) I had to figure out how much fuel to remove from the tanks before flying it so the CG range would work.
Once in the air it needed no trim. Rolls were a little slower on low rates. I haven't tried high rates on anything yet until I get a few more flights on it. I flew it right after warming up on one of my single engine SEs and I'd have to say it was much less affected by wind probably due to the extra weight. It did loops just as tight as the others.
As far as landing went, I seemed to need just a little more runway than the others but I really can't give much of a description here since I was so nervous and now it all seems like a blur. But it did come in well and both engines were running when I stopped. The second flight I came in a little hard which is what messed up the gear but again, both engines were running.
Hopefully next weekend I'll get some in-air pictures. If anyone wants to try this please let me know, I've got tons on build pics and would like to see how others would do it.
Damon
