RE: Tip Stalling Airplane
Thanks for all your help guys....I don't believe the CG is too far forward. Wing and stab incidence are within 1/2 degree of each other (around 0 degrees). The plane flies a little nose heavy (5 clicks of up trim ...about 1/16" on the elevator) but feels good. I have the CG about 3/8 of an inch forward of the instructions and I like it here. I know lateral balance is not the issue (it is very close). I will try to reflex the ailerons up about 1/16". Any other suggestions....................Thanks Steve
