RCU Forums - View Single Post - Range Check
Thread: Range Check
Old 06-06-2005 | 04:41 PM
Bax
Default RE: Range Check
We'll be glad to examine your items to see what might be wrong. You're right, if you have known, good receivers, then the transmitter module may be suspect. You'd only need to send the module to us, and not the entire transmitter, since you mentioned that it's working well with a 72 MHz module.
