RCU Forums - View Single Post - JetCat P60 Oring Replacement DIY
Old 06-06-2005 | 05:58 PM
rcguy!'s Avatar
rcguy!
My Feedback: (69)
Default RE: JetCat P60 Oring Replacement DIY
Next we'll remove the starter housing by unsoldering the two wires from it. Label one leg with the matching color wire first!
Gently wiggle it out from the turbine housing
I used a soldering aid with 2 alligator clips on it to hold the starter housing vertical.
I dribbled some debonder into the Oring cavity and waited a few minutes for it to do its job.
Dig out the old Oring as carefully as you can with a small screwdriver or whatever you feel comfortable with.
Squirt additional debonder into the cavity and work out any fragments that are left.
A final cleaning with a cotton swab or two will leave no trace of the old Oring. I used a short blast of bottled air to assure all was clean.
ID:	281290   Click image for larger version
ID:	281291   Click image for larger version
ID:	281292   Click image for larger version
