Esc Help
The controller you have has a BEC battery elimination circuit. when you reach the minimum voltage to run the servos it cuts off the motor so you have power to land the plane. You can get the motor to start again by closing the throttle and opening it again but it will cut off soon after when the voltage drops again. I had the similar questions when my first plane did the same thing. If you add a cell or two you will get some fly time. Enjoy
