RE: XTM EXCELERATOR HELP
You can soften the rear springs a little allowing it to squat a little more giving it more traction. If you are running the stock engine it's a beast and has way more power than needed in the small truck so throttle control is key. Just lower the rear abit by unscrewing the preload on the shocks a little and that should help alot.
