RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 06-07-2005 | 04:05 PM
  #2546
Evil Homer
Default RE: U-Can-Do 3d 46?
Hitec wires up the same as Futaba, normally channel 6 is other Aileron servo firstly, next some radio dont support dual elevator servo so you have to set up a PMIX to do it, bugger is sometime the trim does not work between the two channels, found out on my JR8103 using a 4 channel RX with dual aileron servos, long story[>:]
Give it a bash with the servo removed for ch5 into ch6, then try PMIX for ch 2 to ch 5, alternatively Y lead
