RCU Forums - View Single Post - Knife Edge Switch
Old 10-09-2002 | 12:34 PM
MinnFlyer's Avatar
MinnFlyer
Default Knife Edge Switch
Sorry, but I agree with 3dbatixkid. Use the brain in your head instead of the one in your transmitter. It will make you a better flier IMHO. If your plane pitches toward the landing gear during a KE, hold a little up elevator. Is that so difficult? Do you use special mixing for a cross-wind landing, or do you manually feed in some slip? You guys will spend hours programming the exact amount of mixing into your transmitters, and then learn to fly at just the right speed so the mix works, but you won't bother to just manually feed in the correction! No, that takes thinking and coordination. Too much trouble.
