ALWAYS set the controls to the usual standard----left is left, right is right, up is toward your belly, down is away from your belly, up throttle is forward, down throttle is back (toward your belly). These are the conventions for all aircraft, and if you teach yourself bad habits, you'll only confuse yourself later!
Anyone who gaveyou other advice doesn't know much about flying!!!!
Good luck and "keep 'em flying".
