Bme 50
I spoke to Keith about the BME55 EXTREME just the other day.
Same cylinder as the 110 same exhaust as the current 50 weight with ignition and plug is a tad over 2 lbs. It will have a radial mount that COMES WITH IT and bolts directly to your firewall. Carbueration is through a set of reed valves that is mounted in front of the cylinder directly over the crank. He is talkin about spinning 24" props with this engine. It will have the same size prop hub as the current 55.
You better call and get your name on the list now because........
THEY ARE GOING FOR $499 just like the current 50
