recommendations...
And LHS means your "Local Hobby Shop"
And by all means, build a kit. The ones suggested are as easy as "Put tab "A" into Slot "B".
Another advantage to kits is this... The ribs (for example) are die-cut from a sheet of wood. So you get a sheet of wood with several ribs cut in it (see picture). You want to save some of these pieces. They come in handy for scrap when you need to make repairs, and they can be used as templates in case you ever have to "Re-make" a part.
