RE: radio interference
You can find a lot of words about interference in the forum, try search.
You can also check this: never metallic pushrods between the trottle servo and the engine.
If you use pull-pull system the cables must not to be in contact each other. If the "interference" was only with the engine running check all the cables, switches and plugs. Warning with very long servo extensions. Good luck
