RE: Four star build
the engine was accidently done like that.i am changing it next time i work on the fuse. The cheeks have been cut off on top, so the carb looks very high. Where the needle valve is, i had to cut off alot of cheeks.
The gear makes the plane look messed up, one of the wheels were lose, and i lost the allen wrench to fit the wheel which i have found and fixed.
And as for legomen, Weight shouldn't be a problem with legomen, they aren't heavy at all, this plane will also be exceptionally powerful too..
