RCU Forums - View Single Post - .46 OS FXi
Thread: .46 OS FXi
Old 06-09-2005 | 11:12 AM
buckskin
Default RE: .46 OS FXi
The screw with the spring on it is the throttle stop screw.The idle mixture screw is inside the barrel on the right hand side of the carb where the linkage hooks up. Look at the exploded views in your manual it labels all of the parts and screws and shows how they go together. Only turn the idle mixture (low end) screw a little at a time it is more sensitive than the high end needle.
