RE: The New 4D PPS from Ikarus
it would work, but the violent change in torque from anticlockwise to clockwise ( or vice versa ) would probably twist the front off a shocky? on a note regarding the ikarus red motor that appears to be an axi 220454? it is not that motor, the hub part that a fixed pitch prop would go on is about 4mm further forward from the rotor. also, the motor in axi terms would be a 2205?? ( don't know the wind ) so it may well have 30% more oomph than the 220454.
